T-Rex of America Forum for T-Rex Enthusiasts
Posted: Fri Feb 19, 2010 1:05 am Post subject: Part Numbers |
Rear Sprocket
1997 ZX-11
Axle Bearings, Rear, From Top L-R (3 total):
(5205 series), (6205 series), (6205 series)
* * * Misc manufactures part #'s (5205 series)
BCA 5205KZZE, Torrington/Fafnir W205PP, NSK 5205DU, MRC 5205CZZ, Motion Industries 00044229
* * * Misc manufactures part #'s (6205 series)
NTN 6205LB, Timken/Fafnir 205PP, NSK 6205DU
Axle Bearing Seal
"TTO" E2117 2 TC 30 52 7
Sprocket/Axle Hub "O-Ring" Just a plain "O" ring 3/32 x 2 1/4. (twn454)
Battery:
YUASA YTX20L-BS
1400R Air Filter (is not stock ZX-14)
NAPA GOLD 6138
1100/1200 Air Filter
K&N High-Flo Air Filter KA-1093
Headlamp Bulbs (4)
Sylvania 9005's
Front Bearing/hub assymbly
Federal-Mogul/BCA/National S-513012
Reverse Gearbox Shaft Seal
SKF-4913 (twn454)
Cush drive rubber blocks
Custom Campagna units, part # MPB 66000
FAN SWITCH Campagna part # MPM 039
Oil filter numbers for the 1200
Kawasaki ZZR1200 ~ part number 16099-003
Radiator Fan Produced by SPAL
SPAL 10" Low Profile 12v Pusher
Part# VA11-AP8/C-29S FAN (10)"
Buy online : http://www.spalusa.com/store/main.aspx?p=itemdetail&item=30100374 |
loki
Posted: Thu Feb 02, 2012 5:25 pm Post subject: |
| Have a new one if someone needs it! |
Gary Contributing Member
Posted: Mon Oct 14, 2013 8:59 am Post subject: |
Notes about Front Bearing/hub assymbly
This is the right part number, but you will need to make the following modifications in order to use it:
1. (Easy) Drill the bottom two mounting holes out to half inch.
2. (Not so easy) Drill and tap a quarter inch 20 tpi hole in the center of the inside spindle to attach the speedometer bolt. I used a lathe to do this, as it is critical that this hole be centered and square.
Also, a warning about the cheap Chinese hub available at NAPA. Don't be impatient like I was and settle for the Chinese version when the SKF version is not available. I wanted to ride Saturday and could only get the Chinese units by the next day. I drilled the holes out and fitted the passager side unit, only to find the studs were so badly aligned that I couldn't get the brake rotor back on. Needless to say, I returned both hubs and waited for them to order in the SKF units.
Hope this helps someone else, Gary |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
