gotcha72 Contributing Member
Posted: Wed Mar 31, 2010 12:19 am Post subject: Knocking Noise |
| Is anyone familiar with a knocking noise that comes when you accelerate in any gear. As I speed up so does the noise. Its not coming from the engine. Not sure how to expain any other way. Any and all help would be appreciated. |
Posted: Wed Mar 31, 2010 1:20 am Post subject: |
bearINGS??? _________________ "OUT TO LUNCH" and not coming back. |
Posted: Wed Mar 31, 2010 7:05 am Post subject: |
beeeaaaaaaaaring........... _________________ si ca marche pas.....prend un marteau
loki
Posted: Wed Mar 31, 2010 11:44 am Post subject: |
| Jack up the rear start rex,put in gear--look for chain,bearing and sprocket noise--and lube the chain its the easiest way! |
Posted: Wed Mar 31, 2010 11:53 am Post subject: |
| thanks for the help, is there a way to check the bearing? |
Posted: Wed Mar 31, 2010 12:23 pm Post subject: |
Do what Loki said. If there is noise other than chain, then remove the rear axel and check the bearings. It will be obvious if it is bad. _________________ 2010 White/Silver 14RR
Posted: Wed Mar 31, 2010 12:27 pm Post subject: |
If you can connect an oil pressure guage to the motor, then you can determine if your bearings are bad. If the oil pressure increases/decreases in smooth gradual steps, your bearings are fine, However, if the guage flickers, your bearings are bad. Ignoring the problem could end up with a rod through the side of the engine.
If it is a bearing problem, your crank is probably scored. Solution is a new crank. Bottom line, sounds like you have an EXPEN$IVE problem. Cheap solution in the future is to change the oil regularly and a new oil filter at each change. _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
loki
Posted: Wed Mar 31, 2010 6:54 pm Post subject: |
| Verify its not the engine!!sexy is gonna give you a heart attack!!unfortunately he is right!binding chain,worn sprockets and bearing are usually a good bet though!good luck!! |
Posted: Wed Mar 31, 2010 7:47 pm Post subject: |
| Sexy_Rex wrote: | If you can connect an oil pressure guage to the motor, then you can determine if your bearings are bad. If the oil pressure increases/decreases in smooth gradual steps, your bearings are fine, However, if the guage flickers, your bearings are bad. Ignoring the problem could end up with a rod through the side of the engine.
If it is a bearing problem, your crank is probably scored. Solution is a new crank. Bottom line, sounds like you have an EXPEN$IVE problem. Cheap solution in the future is to change the oil regularly and a new oil filter at each change. |
no no no no.........the bearing in the rear wheel......not the motor.....he said it's speed up with the speed of the bike......it's a wheel bearing for sure.......
if it was the motor it will do it even in idle....... _________________ si ca marche pas.....prend un marteau
Posted: Wed Mar 31, 2010 7:48 pm Post subject: |
60$ fix the problem...  _________________ si ca marche pas.....prend un marteau
fina920 Contributing Member
Posted: Wed Mar 31, 2010 8:00 pm Post subject: clunking |
| I had the same noise coming from the rear end two years ago and I went right for the bearings. Turned out there was a kink in the chain and each time it went around the sproket it would make a loud clunking noise. I soaked the chain in kerosine and then lubed it up. Noise was gone. Rick was a huge help on this. Try the chain first. Go slow and if you hear the clunk less frequent then you do at high speed I would go with the chain. If not then def the bearings. My two cents. |
twn454 Killers Dad
Joined: 03 Jun 2009 Posts: 133 Location: Fort Washington, Md
Posted: Wed Mar 31, 2010 9:11 pm Post subject: |
| I got my money on the chain and sprockets! |
murphy Contributing Member
Posted: Wed Mar 31, 2010 11:04 pm Post subject: |
same thing just happened to me i thought it was the chian checked it lubed it tightened it then look at the e-brake, then finally called eric and he said it was the bearings and it was. If you can hear it clunkin while just rollin down a hill(like a driveway in neutral) slow its prolly them.good luck. _________________ myspace.com/starboymurphy |
Posted: Thu Apr 01, 2010 7:02 am Post subject: |
| twn454 wrote: | | I got my money on the chain and sprockets! |
ok i pick the bearing.....  _________________ si ca marche pas.....prend un marteau
