Cush drive assembly
Post new topic   Reply to topic    T-Rex of America Forum Index -> Technical
Gary
PostPosted: Sat Aug 01, 2009 6:57 pm    Post subject: Cush drive assembly Reply with quote
Can anyone provide the secret on how to re-assemble the cush drive after replacing the rubbers?
I am using silicon spray as lubrication, but cannot get the paddles to slide between the new rubbers.
I went as far as to place the T-Rex on stands and try to use the jack to force them in. I placed the cushdrive between the jack and the swing arm and lifted the T-Rex off the stands, but still the paddles would not slide into position?
I have successfully re-assembled it in the past with the old rubbers, but cannot do it after installing the new ones. Any ideas?
Are all the rubbers the same? I have a 2003. Are they the same all the way through 2007?
J-rex
PostPosted: Sat Aug 01, 2009 7:35 pm    Post subject: Reply with quote
Check twn454's posts he describes grindding the paddles slightly to make a tappered edge.
J-rex
PostPosted: Sat Aug 01, 2009 7:38 pm    Post subject: Reply with quote
Under 07 technical catagory thread "hockey puck installation".
K3
PostPosted: Sat Aug 01, 2009 9:18 pm    Post subject: Reply with quote
Grind some metal off the edges of the small blocks and lube it, (Ricks recomendation) worked great.
Gary
PostPosted: Sat Aug 01, 2009 11:24 pm    Post subject: Reply with quote
JRex and K3, thanks for the replies,
That makes perfect sense. You wonder why you didn't think of it yourself after someone else points it out.
Good thinking Rick. I'll put the Dremel to work tomorrow.
Thank goodness we still have a resource like this site. Cudos to Wayne for doing the hard work and providing this great site.
Post new topic   Reply to topic    T-Rex of America Forum Index -> Technical All times are GMT - 4 Hours
