Posted: Thu Aug 04, 2011 8:40 am Post subject: 1100cc Engine #3 Rod Bearing Problem |
These engines are known for not delivering enough oil to the #3 rod bearing. Next thing you know is a blown engine. Mr Turbo in Houston has the fix. Send your oil pan to Terry. He makes a modification to the oil pan to relieve the problem. You will need to buy an OEM gasket from Kawasaki. _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Posted: Thu Aug 04, 2011 5:17 pm Post subject: |
that's good........long time problems.........  _________________ si ca marche pas.....prend un marteau
