bobconc
Posted: Tue May 17, 2011 11:28 pm Post subject: gas pedal adjustments |
hi new to the t rex world Bought the blue 06 that Rick had for sale... Im in the middle of doing a full look over,tune up and ect.. and was wondering about the gas pedal cable, its not pulling back. seems like it has to much slack. i figured how to adjust it but ,also see that there are stop adjustments (forward and back)to stop the pedal from going to far. Is there a certian distance it should travel back. Thanks
ps.... all the info on the site is great Thanks!!! |
Posted: Wed May 18, 2011 12:30 pm Post subject: |
the stopper in front of the pedal is there for stopping the pedale flush with the two other....the one in the back is there to prevent you from snapping the cable when you push the pedal to the floor...you should hit this stopper before the end of the cable ( the butterfly full open ) _________________ si ca marche pas.....prend un marteau
bobconc
Posted: Wed May 18, 2011 9:50 pm Post subject: |
| ok thanks ..thought maybe there was a certian distance the pedal should travel. cable seems little streched out .I will line it up with the other two and adjust the cable.. Thanks |
