K3 Contributing Member
Posted: Fri Jun 12, 2009 11:29 pm Post subject: hockey puck instalation |
For all of you that have done this any tips for this wonderfull upgade. I replaced a bearing tonight and cleaned up the hub to install the new dampners in the moring.
Any tricks other than the lube ? |
Geezer Contributing Member
Posted: Sat Jun 13, 2009 12:24 am Post subject: |
Heavy duty C-Clamps...........worked for me.
Geez |
twn454 Killers Dad
Joined: 03 Jun 2009 Posts: 133 Location: Fort Washington, Md
Posted: Sat Jun 13, 2009 7:28 am Post subject: |
| On the hub assembly the three ears that insert between the dampers take those and grind the sharp edges off on the two outsides where they come in contact with the dampers, this will let them slide in between them much easier. |
Posted: Sat Jun 13, 2009 11:30 am Post subject: |
| twn454 wrote: | | On the hub assembly the three ears that insert between the dampers take those and grind the sharp edges off on the two outsides where they come in contact with the dampers, this will let them slide in between them much easier. |
Great minds think alike,i did that in the preperation stage last night, the
C clamps worked great as well.
Maybe camapana can upgrade the big hex nut to a wing nut so It is easier to replace the rear bearings. |
