fina920 Contributing Member
Posted: Thu May 27, 2010 12:06 pm Post subject: bucking |
| while driving at around 5,000 rpm rex is bucking like crazy. Most notable on highway in 6th gear. I do not know where to begin looking. I have new plugs in it so do not think it is that. Any ideas would be great. |
Posted: Thu May 27, 2010 12:58 pm Post subject: |
what years???
if it's fuel injected, check the hi press pump in the back, we had a similar problem on a 2009..... _________________ si ca marche pas.....prend un marteau
Posted: Thu May 27, 2010 1:08 pm Post subject: |
Check the small clear tube from the ram air to the carbs and check to see if the black plastic piece that it goes to is cracked. _________________ X-treme-toyz.net
Posted: Thu May 27, 2010 5:51 pm Post subject: bucking |
this tube appears to be fine, but I do hear back firing coming from that side ever once in a while when down shifting. The tube seems very short. How do you replace this tube? Where do you get it from?
My rex is an 03 non fuel injected. |
Posted: Thu May 27, 2010 6:33 pm Post subject: |
| It's just a clear piece of hose home depot has it i'm sure... or even a pool supply store might be able to sell you something that small. |
loki
Posted: Thu May 27, 2010 10:06 pm Post subject: |
| Dirty carbs!if u are getting carb backfires and rough running its usually after it sits for awhile or after u fill up!pull em and clean em:( |
Geezer Contributing Member
Posted: Thu May 27, 2010 10:23 pm Post subject: |
I just had one of my carb sync port covers crack and come
off. Thought I had bad gas, ran like sheet.
Take a visual of them between the carb and manifold, ya
just never know.
Geez |
