WINK Contributing Member
Posted: Sat May 01, 2010 2:04 pm Post subject: Windshield brackets |
| what brackets should i use for my winshield. I use screw right now and they keep coming out. |
Posted: Sat May 01, 2010 2:39 pm Post subject: |
| what am i suppose to look under? |
Posted: Sat May 01, 2010 3:11 pm Post subject: |
Thank you Richard - sorry Wink and they will look like this... I use these p-clamps when I sell my windshileds, they are worth the $$$
Posted: Sat May 01, 2010 3:17 pm Post subject: |
| Thanks really appreciate it. also what did you use at the bottom of your winsheld to keep it from rubbing against the body? |
Posted: Sat May 01, 2010 5:14 pm Post subject: |
The windshields are slightly different on the 1400's vs the 1200 T-Rex's. Overall they are the same dimension, however, on the 1400, the notch has to be a little deeper because of the difference in the air scoops. FYI _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Posted: Mon May 03, 2010 12:23 am Post subject: |
| WINK wrote: | | Thanks really appreciate it. also what did you use at the bottom of your winsheld to keep it from rubbing against the body? |
small pcs of weather strip _________________ "OUT TO LUNCH" and not coming back. |
GuyIII
Posted: Mon May 03, 2010 12:04 pm Post subject: |
| You can go to Lowes or Home Depot and buy the small black vinyl hose about 3/8" diameter. Use a new Exato knife and cut a slit down one side. You can then slide the hose over the lower edge of the wind shield and it will keep it from rubbing against the body. |
