Posted: Wed Jun 10, 2009 9:27 pm Post subject: Rear Speakers |
Poly-Planar® MA840 Sub-Compact Box Speakers
3'' Dual Cone
Do a search via Amazon.com for the best price.
You can mount these speakers by using the "Tall Man" bolt holes. Get 1" square aluminum stock, end caps, and a sheet of flat aluminum. If my memory is correct, cut the square aluminum to 12 5/8". Mount the speakers on the 1" square stock, mount this assembly approximately 1" forward of the bolt holes on the flat aluminum sheet. Centerline of the bolt holes is 10 5/8". Bend down the flat sheet 90 degrees for extra strength for the mounting plate. Please check your measurements to see if the above information is correct.
 _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
