Questions
Geezer
PostPosted: Sun Apr 04, 2010 1:29 am    Post subject: Questions Reply with quote
My ZX-1100 rex has a few quirks that I wonder if they are normal ?
1.) I get a buzz vibration thru the steering wheel and shifter.
Bearing are good, sprokets are new and the chain also.
Valves are adjusted, carbs are sync.......runs very well
no other problems.......
Only idea I have is the reverse outer bearing ?? Could this
be the problem ? Reverse works well, so must have been
rebuilt at one time.
Or maybe this is normal ??
2.) I would like to change the ride height one or two inches, taller.
Would this require different springs or springs and shocks?
Thanks for you input.....
Geezer
loki
PostPosted: Sun Apr 04, 2010 8:54 am    Post subject: Reply with quote
I replaced my outer bearing on the reverse box and it made a huge difference on vibration!check all motor mounts-i had several loose and one was broken!any questions gimme a call!
