pj1r1 Contributing Member
Posted: Sat Mar 20, 2010 8:04 pm Post subject: looking for the hickstand switch wiring |
i am trying to locate the wiring for the kickstand switch for 2006 ,(if it is on the rex) is there a plug that i can get too . _________________ if you aint hittin the rev limiter you just aint going fast enough |
Posted: Sat Mar 20, 2010 9:37 pm Post subject: |
Kickstand switch  _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Posted: Sun Mar 21, 2010 7:45 am Post subject: |
i do belive that we are using the wire harness from the kawasaki zzr12oo (and 1400's (most bikes do have kickstand switches that prevent you from leaving in gear . they are a set of wires that usually come off the kickstand switch and up to the wire harness......... i am looking for the end of the harness where the switch plugs into I DONT BELIVE THAT THEY CUT IT OUT BUT NOT SURE IF I AM LOOKING FOR SOMETHING THAT IS NOT THERE OR NOT _________________ if you aint hittin the rev limiter you just aint going fast enough |
ViperSSSS Contributing Member
Joined: 20 Dec 2009 Posts: 106 Location: San Dimas, CA
Posted: Tue Mar 23, 2010 12:58 am Post subject: |
#6 = Kickstand Switch
#11 = Junction Box
#14 = Main Relay
That's probably enough info to see if it's there. Hope it helps! _________________ 2007 Blue T-Rex 1400R
Muzzy M10 Full Exhaust - Flies Removed - PCV with Autotune |
Posted: Tue Mar 23, 2010 6:53 pm Post subject: |
| Nice work viper!! |
