sean Contributing Member
Joined: 11 Mar 2010 Posts: 13 Location: Minneapolis, MN
Posted: Sat Mar 20, 2010 4:52 pm Post subject: Hmmm antifreeze under the trex?? |
| I went out to the garage this afternoon to start getting the rex ready for summer and there is a puddle of antifreeze under it. My garage stays warm all winter so nothing should have froze. Any ideas? |
Posted: Sat Mar 20, 2010 7:09 pm Post subject: |
I have had the same happen. Starts leaking out of one of the radiator hose connections. You can try what I did. Feel for which one is wet, then undo the clamp, loosen that joint (twist it) and retighten. If that doesn't work, then you likely need some new parts. _________________ 2010 White/Silver 14RR
Posted: Sat Mar 20, 2010 7:14 pm Post subject: |
| GRex wrote: | | I have had the same happen. Starts leaking out of one of the radiator hose connections. You can try what I did. Feel for which one is wet, then undo the clamp, loosen that joint (twist it) and retighten. If that doesn't work, then you likely need some new parts. |
Yea I read some old posts and this seems to be a common problem. I gonna head out to the garage and check all of the connections. |
Posted: Sat Mar 20, 2010 9:30 pm Post subject: |
| Sure enough there were a few things that needed to be tightened. I guess I should flush it and replace the coolant anyway, anyone know how much coolant there is in this system? |
Posted: Sat Mar 20, 2010 9:44 pm Post subject: |
The factory has fixed that problem. They now offer a one piece radiator hose to replace the reducer that leaks. I have them in stock if anyone needs them.
MPM23500.........$30.99
MPM23400.........$22.99 _________________ X-treme-toyz.net
Posted: Sat Mar 20, 2010 9:51 pm Post subject: |
| WAYNE 07 wrote: | | The factory has fixed that problem. They now offer a one piece radiator hose to replace the reducer that leaks. I have them in stock if anyone needs them. |
I will take one. That way it will be fixed right. I also sent ya a msg about some rear bearings and crush drive.
THANKS!! |
