ViperSSSS Contributing Member
Joined: 20 Dec 2009 Posts: 106 Location: San Dimas, CA
Posted: Wed Mar 17, 2010 9:34 pm Post subject: Older Rear Side Lights on a 2007 |
Anyone know if the older rear side light lenses will fit in the hole that is cut out of the 2007? I'm sure there would have to be some modification, but I would be interested in doing this if someone knows where to get the lenses. _________________ 2007 Blue T-Rex 1400R
Muzzy M10 Full Exhaust - Flies Removed - PCV with Autotune |
Posted: Wed Mar 17, 2010 9:51 pm Post subject: |
I do beleive they will fit if you find a used set but when ordering a new set they come larger than you need and you have to grind them down to fit. There are 2 pieces per side. _________________ X-treme-toyz.net
Posted: Fri Mar 19, 2010 9:44 pm Post subject: |
Anyone have these lenses available for sale in red or clear?
I could get a new set, but I bet I would mess them up if they need grinding. _________________ 2007 Blue T-Rex 1400R
