ViperSSSS Contributing Member
Joined: 20 Dec 2009 Posts: 106 Location: San Dimas, CA
Posted: Wed Mar 10, 2010 11:28 pm Post subject: Switched Power / PCV Speed Sensor |
I would like to know where I can tap a switched 12v directly behind the firewall if anyone can help me out. I know I can use the seat belt buzzer in the front. I am sure I could trace back the tail or side light, but I figure it will take less time if I ask. I tried the power for the speedo healer, but it only registers like 10v with the key on.
Also, does anyone know the pinouts of the speedo healer? I would assume I could tap the speed sensor there for the PCV, but I don't know which one is in or out. _________________ 2007 Blue T-Rex 1400R
Muzzy M10 Full Exhaust - Flies Removed - PCV with Autotune |
Geezer Contributing Member
Posted: Wed Mar 10, 2010 11:43 pm Post subject: |
Mine is a older unit -2001.
I found one power wire under the dash but was so small
in gage size, it was useless.
I ended up running a 12 gage wire from the battery to behind the
dash, hooked up to a 6-post fuse box for positive. Then drilled
through the mirror bracket and made a common ground bracket.
Now everything I add is plug and play.
Good luck with your project
Geezer |
