Posted: Tue Jul 19, 2011 9:43 pm Post subject: Oil Pump Gear - High Volume for ZX-14 Motor |
One of the weak areas of the ZX-14 engine is the #3 cylinder. Low pressure and volume could throw a rod thru the engine block. Installing a High Volume Oil Pressure Gear can increase the oil presure by 8% to 9.2%. Cost is in the $110 - $115 range. Couple of WEB sites, but there are others out there:
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=5203759&showprevnext=1 P/N: 1400-70
http://zxzone.com/cranks.html P/N: OPGX14
Easy install behind the clutch. _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
