mellowcmb Contributing Member
Joined: 10 Dec 2009 Posts: 123 Location: South Pasadena, Ca
Posted: Wed Jan 13, 2010 6:36 pm Post subject: Coolant |
Hey guys,
I think I've got s coolant leak somewhere and my reserve is running low. I just wanted to know what type I should be adding. Any help would be appreciated. Thanks. |
Posted: Wed Jan 13, 2010 8:22 pm Post subject: |
| reqular good old green coolant... If i may make a suggestion check the lower hose connections at the radiator & the reducer to the hose |
Posted: Wed Jan 13, 2010 8:33 pm Post subject: |
If it is leaking where the hose/reducer goes into the radiator there is a new design that eliminates the reducer and solves the problem. (or just tighten it for now) _________________ X-treme-toyz.net
Posted: Wed Jan 13, 2010 8:43 pm Post subject: |
| Thanks guys. I seemed to have narrowed the leak to a hose right above where the headers turn into 1 pipe. Is this the reducer you guys are talking about? |
Posted: Wed Jan 13, 2010 8:56 pm Post subject: |
If you are talking about where it goes into the radiator than yes. _________________ X-treme-toyz.net
Michaelg Contributing Member
Joined: 04 Jun 2009 Posts: 129 Location: Wheaton Illinois
Posted: Wed Jan 13, 2010 9:01 pm Post subject: |
| Mine leaked upper and lower, They were hand tight from factory (good quality control!) |
