View previous topic :: View next topic |
Author |
Posted: Sun Dec 13, 2009 5:54 pm Post subject: Wilwood Brake Calipers |
Can anybody tell what the model number of the front and rear disc calipers are for a 2007 T-Rex? Same question, but for the 2009?
The reason for this questions is Johnny stated to me that Campagna used a larger disc caliper and brake pad for the 2009's because it was found the the rear bearing problem was caused by to much heat from the rear brake. I am going to assume that small brake pads caused more contact time to the disc rotor to produce the heat problem. Did Campagna go from a 4 piston system to a 6? Thx _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Back to top |
Posted: Sun Dec 13, 2009 6:25 pm Post subject: |
Front calliper are the same 07 and 09. Rear caliper is a complete new set up. If you want to upgrade your 07 to 09 in the back , you will need caliper,caliper support, shim for the wheel, rear master cylinder,hand brake cable,and brake handle.... . |
Back to top |
Posted: Sun Dec 13, 2009 6:43 pm Post subject: |
Chicknfeet, do you understand all this? Give me feedback. _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Back to top |
Posted: Mon Dec 14, 2009 1:18 am Post subject: |
JOHNNY wrote: | Front calliper are the same 07 and 09. Rear caliper is a complete new set up. If you want to upgrade your 07 to 09 in the back , you will need caliper,caliper support, shim for the wheel, rear master cylinder,hand brake cable,and brake handle.... . |
Don`t forget the rotor _________________ X-treme-toyz.net
Back to top |
Posted: Mon Dec 14, 2009 12:12 pm Post subject: |
Sexy_Rex wrote: | Chicknfeet, do you understand all this? Give me feedback. |
sure thing... I would love to get you prices however the factory is in middle of a pricing restructure – but I will request the prices _________________ "OUT TO LUNCH" and not coming back. |
Back to top |
Posted: Mon Dec 14, 2009 10:06 pm Post subject: |
chicknfeet wrote: | Sexy_Rex wrote: | Chicknfeet, do you understand all this? Give me feedback. |
sure thing... I would love to get you prices however the factory is in middle of a pricing restructure – but I will request the prices |
That sounds expensive!!! |
Back to top |
