Wideband cotroller
Post new topic   Reply to topic    T-Rex of America Forum Index -> Mods & Stuff
Michaelg
PostPosted: Fri Aug 28, 2009 7:52 am    Post subject: Wideband cotroller Reply with quote
I use this as the T-Rex fuel ratio is not good all the time, You have to weld a Bung on one of your exxhaust pipes. This will allow you to tweak your Power commander with out a Laptop. http://cgi.ebay.com/ebaymotors/AEM-GAUGE-WIDEBAND-UEGO-CONTROLLER-30-4100-AEM-DEALER_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem35a329e793QQitemZ230370699155QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories MONITOR AND CONTROL AFR THROUGH ONE UNIT
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM's Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED "needle" that changes colors as the AFR changes from rich to lean. The unit's 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
haya
PostPosted: Fri Aug 28, 2009 8:17 am    Post subject: Reply with quote
i use a NGK WIDEBAND AFX. the number on the display are bigger you can read it at 100mph.
Michaelg
PostPosted: Fri Aug 28, 2009 8:25 am    Post subject: Nice Unit Reply with quote
http://cgi.ebay.com/ebaymotors/NGK-AFX-Powerdex-Wideband-Air-Fuel-Monitor-Gauge-91101_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem335494dea2QQitemZ220462374562QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
haya
PostPosted: Fri Aug 28, 2009 9:53 am    Post subject: Reply with quote
you can run some V.P gaz with this sensor, i run it with some turbo and never have problem.
Michaelg
PostPosted: Sun Sep 20, 2009 7:28 pm    Post subject: Final installation Reply with quote
Post new topic   Reply to topic    T-Rex of America Forum Index -> Mods & Stuff All times are GMT - 4 Hours
