Posted: Tue Jun 30, 2009 11:23 am Post subject: Running Hot? |
Ok so I am the proud owner of a 1400 however I am having one small problem which I never really encountered on a 1200.
HIGH ENGINE TEMPS
The temp gauge read 5 bars (or all the way to the top) anyone have any insight into this?
All comment would be greatly appreciated  _________________ "OUT TO LUNCH" and not coming back. |
Posted: Tue Jun 30, 2009 11:41 am Post subject: |
Mine has always run on the "hot" side. On the other Forum, Milsap measure the heat off the engine and the temp was in the more normal range. His conclusion was the gauge was not accurate. _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Posted: Tue Jun 30, 2009 11:43 am Post subject: |
good to hear  _________________ "OUT TO LUNCH" and not coming back. |
twn454 Killers Dad
Joined: 03 Jun 2009 Posts: 133 Location: Fort Washington, Md
Posted: Tue Jun 30, 2009 3:28 pm Post subject: |
| Does your bike have the air deflector underneath, bottom side of the radiatior? If not it will make a world of diffference! |
Posted: Tue Jun 30, 2009 4:45 pm Post subject: |
| twn454 wrote: | | Does your bike have the air deflector underneath, bottom side of the radiatior? If not it will make a world of diffference! |
yes sir... I think I will add water wetter. _________________ "OUT TO LUNCH" and not coming back. |
Posted: Tue Jun 30, 2009 11:45 pm Post subject: |
WATER WETTER AND COOL AIDE are good to add to prestone or pure water. Since this was not enough , I am running with an extra fan. I am not to much of a computer expert but ,I will try to get Haya to take pictures and post them. Also had to replace the fuse for a 20 amp instead of 15. Running idle with hi-beam and 4 way flasher was not an issue. Test last 2 hours. Now running on race track , 240 miles in a day. Outside temperature was 90 degree. Turn off the motor for re-fuel only.  |
Posted: Wed Jul 01, 2009 1:51 pm Post subject: |
| JOHNNY wrote: | WATER WETTER AND COOL AIDE are good to add to prestone or pure water. Since this was not enough , I am running with an extra fan. I am not to much of a computer expert but ,I will try to get Haya to take pictures and post them. Also had to replace the fuse for a 20 amp instead of 15. Running idle with hi-beam and 4 way flasher was not an issue. Test last 2 hours. Now running on race track , 240 miles in a day. Outside temperature was 90 degree. Turn off the motor for re-fuel only.  |
great thanks for the info... Looking forward to seeing some pics from haya _________________ "OUT TO LUNCH" and not coming back. |
haya Contributing Member
Joined: 04 Jun 2009 Posts: 290 Location: Québec ,canada
Posted: Wed Jul 01, 2009 4:43 pm Post subject: |
Posted: Wed Jul 01, 2009 4:57 pm Post subject: |
thank you!  _________________ "OUT TO LUNCH" and not coming back. |
Posted: Wed Jul 01, 2009 7:22 pm Post subject: |
| for the fan model . p.m johnny he can tell you the mod to do on the fan to fit well. me i put a switch and solenoide to control the fan. |
