Geezer Contributing Member
Posted: Sun Jul 26, 2009 9:11 pm Post subject: |
Is it street legal?
How fast does it go?
How much does it cost?
Is it fun?
Whats the gas mileage like?
No but seriously where can I get one? _________________ X-treme-toyz.net
LIFE`S TOO SHORT |
lex
Joined: 24 Jul 2009 Posts: 86 Location: Québec, Canada
Posted: Thu Jul 30, 2009 8:33 pm Post subject: |
C'est completement débile cette machine là !! quelqu'un sait quel est le moteur dans ce kart là ??? _________________ big kart street legal |
GRex Contributing Member
Posted: Thu Jul 30, 2009 10:46 pm Post subject: |
I am curious. You folks talk so much about rear bearing problems. I have not had any problems with my rear bearings. Original bearings, 15,000 miles on my 2005. Is this a problem with the newer T-Rex's? Or something that I will run into later?
Thanks _________________ 2010 White/Silver 14RR
- Albert Einstein |
Posted: Fri Jul 31, 2009 12:16 am Post subject: |
You must only drive in a straight line , you probably hold the record for bearing longevity or your bearings are on their way out  |
J-rex Contributing Member
Posted: Fri Jul 31, 2009 9:53 am Post subject: |
or they are bad and he doesn't know it yet |
Posted: Fri Jul 31, 2009 11:40 am Post subject: |
Don't just drive in straight line. And if they are already bad, they are not loose or making noise.
I will be changing spockets/chain/tire soon so I will inspect them at that point. _________________ 2010 White/Silver 14RR
- Albert Einstein |
Posted: Fri Jul 31, 2009 12:45 pm Post subject: |
well... power too you I don't consider myself to be an abusive operator and mine where not shot but they where starting to make noise ( you could not hear it w/ the engine noise only if u rotated the wheel w/ engine off) @ 7500 miles I believe it was. |
Posted: Fri Jul 31, 2009 1:13 pm Post subject: |
I understand. I use my power more often than I probably should. The darn thing is deafining at 10-11k rpm even with earplugs.
And since I jack it to grease the chain every 300-500 miles, I have plenty of practice spinning the tire and listening to the bearings.
I am convinced that most bearing issues come from improper torque on the axels - ususally over-torqued. That will cause early failures in ball bearings. _________________ 2010 White/Silver 14RR
- Albert Einstein |
Posted: Fri Jul 31, 2009 4:27 pm Post subject: |
valid point regarding the torque. It turns out my axle was overtighten previous to me owning it. |
boonchie Contributing Member
Posted: Sun Aug 02, 2009 12:22 pm Post subject: |
what should they be torqued at? _________________ keep on keepin on!!! |
Posted: Sun Aug 02, 2009 2:03 pm Post subject: |
I don't know the spec but it is not that tight I believe 45ft pounds or less. |
