No start
06roush
PostPosted: Wed Sep 26, 2012 10:11 pm    Post subject: No start Reply with quote
Ok here is the deal I have a 05 that I brought used with lots of mods the issue that I'm having is that it sometimes when I turn the key on I don't hear the fuel pump when that happens it will crank but no start if I hear the pump it starts up but sometimes I get no crank or pump it has 2 fuel pumps one makes a clicking noise and one rumbles if you have any ideas I would greatly appreciate the help thanks
mellowcmb
PostPosted: Thu Sep 27, 2012 1:51 pm    Post subject: Reply with quote
Sounds like you have the same problem I had. I believe you have 2 separate issues here, but others could chime in if I'm wrong. Issue #1: the fuel pumps need to be replaced or fixed. In my case, I would sometimes here the pump click and sometimes I wouldn't. It would normally click when cold and start right up, but after the bike got hot the pump would not work and the bike would not start. I ended up replacing my fuel pumps with 1 Holly Red fuel pump. Issue #2: your starter is going out. This is more of an electrical issue and totally separate from your fuel pump issue. Regardless of what's going on with the pump, the bike should always crank unless your battery is dead or dying. Im having the same problem with my bike and was told that it was an electrical issue. I have not fixed it as of yet, but it only happens when the bike gets really hot. Hope I've helped you out in some way.
loki
PostPosted: Thu Sep 27, 2012 9:45 pm    Post subject: Reply with quote
Clutch switch,neutral safety switch,starter solenoid,fuel pump and relay. Check them all.
chicknfeet
PostPosted: Fri Sep 28, 2012 3:08 pm    Post subject: Reply with quote
This was the main problem on my 05
RexRico
PostPosted: Fri Apr 18, 2014 1:15 am    Post subject: Reply with quote
Just wondering if you got to do these repairs and had any luck with them. I'm having similar issues with my 05, same thing with the rumbling sound from the fuel pump and the no cranking after its hot. I have to let it cool down before it will turn back on. Sometimes I have to even rock it side to side for a bit before wit will turn back on. Right now I'm in the middle of a tear down so I'm thinking about replacing the components you mentioned before as well as upgrade the electrical wiring.
2005 T-Rex 1200
View user's profile Send private message Send e-mail AIM Address
RexRico
2005 T-Rex 1200
Gary
PostPosted: Sat Apr 19, 2014 3:30 pm    Post subject: Reply with quote
Check the ground connection on your battery and where it connects to the engine. I had a bad earth connection and put up with hot starting issues for months before I finally got my ass under there and found a loose earth connection. Problem solved. Never had another issue with starting.
twn454
Killers Dad
PostPosted: Sun Apr 20, 2014 11:12 am    Post subject: Reply with quote
Check the starter solenoid, then get hot and start melting.
