Posted: Wed Jun 10, 2009 7:52 pm Post subject: Fuel Pump Fix |
T-Rex OEM fuel pump went south. Did not provide good volume of fuel for the ZX-14 motor. Motor ran rough.
Solution:
MSD fuel pump- #MSD-2225 (gives 40+ PSI volume)
Fuel Injection Filter - #55172
Hose End Fitting - #KBS-23006
Hose End Fitting - #KBS-790586
Fuel Injection clamps
Cost of Parts: Approxiamately $215.00
 _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
spsilos
Posted: Tue Aug 16, 2011 4:42 pm Post subject: |
I tried the msd 2225, found it to be noise on start and running so i decided to go to advanced auto parts and bought a micro electronics universal fuel pump at 2-4 psi model 42s and so far no clicking sound and no noise on start up. Thanks. |
Posted: Tue Aug 16, 2011 5:42 pm Post subject: |
the fuel pump went south because of the heat from the rad and the header.....all 2009 - 2010 got fix ( relocation kit ), and the 2011 are made like this....
every t-rex with 1400 got fix here...........do you guys talk to campagna from time to time......??? _________________ si ca marche pas.....prend un marteau
Posted: Tue Aug 16, 2011 9:37 pm Post subject: |
getmad2009 wrote: | the fuel pump went south because of the heat from the rad and the header.....all 2009 - 2010 got fix ( relocation kit ), and the 2011 are made like this....
every t-rex with 1400 got fix here...........do you guys talk to campagna from time to time......??? |
Note that if you ever turbo a T-Rex, you will need the MSD fuel pump and the extra PSI.
P.S. What about the 2007's? Do they qualify for the replacement kit? _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
Posted: Tue Aug 16, 2011 11:31 pm Post subject: |
for sure .......a turbo will need a better pump , ans yes , the 2007 had the same pump all the way to 2011....
try to call Wayne , and see with campagna for the relocation kit ......it come with a new pump , hose , and fitting ..... _________________ si ca marche pas.....prend un marteau
Posted: Wed Aug 17, 2011 1:27 am Post subject: |
getmad2009 wrote: | for sure .......a turbo will need a better pump , ans yes , the 2007 had the same pump all the way to 2011....
try to call Wayne , and see with campagna for the relocation kit ......it come with a new pump , hose , and fitting ..... |
Thanks for the info and update.  _________________ 2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
GRex Contributing Member
Posted: Sat Aug 20, 2011 11:54 am Post subject: |
Campagna had my 2010 RR at the factory - but they never modified the pump.
It failed on a cross country trip. I replaced the pump at Barber.
I still need to relocate the pump - but just replacing it was all I could do on the road.  _________________ 2010 White/Silver 14RR
- Albert Einstein |
Posted: Sun Aug 21, 2011 8:20 pm Post subject: |
GRex wrote: | Campagna had my 2010 RR at the factory - but they never modified the pump.
I still need to relocate the pump - but just replacing it was all I could do on the road.  |
talk to campagna ..............it's a shame they dont do recall , and that people get stuck on the road ............ _________________ si ca marche pas.....prend un marteau
