what are these two plugs and vacuum connectors and where do
Post new topic   Reply to topic    T-Rex of America Forum Index -> General Discussion
camaross621
PostPosted: Sun May 01, 2011 4:58 pm    Post subject: what are these two plugs and vacuum connectors and where do Reply with quote
where do these tw things go???
2007 T-rex.. in a million peices
Sexy_Rex
PostPosted: Sun May 01, 2011 6:06 pm    Post subject: Reply with quote
Do you have a speedhealer installed? 2007 and later have this module installed to correct the speedometer. What is your gear ration for the front and rear chain sprocket? Stock is 15/50. I prefer 17/48. just a FYI
2007 T-Rex 1400R - BMW Laguna Seca Blue -Turbo Powered
camaross621
PostPosted: Sun May 01, 2011 6:09 pm    Post subject: Reply with quote
I will have to check on my sprockets but I believe they are stock 15/50. I do not think I have a speed heeler. this looks like a coolant temp connector but its already connected and my coolang guage works...
I have FI light on.. code 62.
im def thinking this vacuum issue is causing no vacuum into the rest of the lines.
Phil
PostPosted: Mon May 02, 2011 12:36 pm    Post subject: Reply with quote
Hi, Code 62 is : Subthrottle valve actuator malfunction, wiring open or short. That actuator controls the opening of the secondary butterflys and it is located between throttle body 2 and 3.
The white connector looks like the one that is conncect to the breather valve that is located between the spark plug 2 and 3. It's hard to tell with the picture but it looks like you dont have this valve. I have no idea about the first picture.
I hope this helps.
camaross621
PostPosted: Mon May 02, 2011 3:40 pm    Post subject: Reply with quote
I hope this helps.
thanks it def helps. the first pic it a huge vacuum line and it connects to every single throttle body.. really confused on this damn thing because Ive looked everywhere for the second end to it and I cant find it anywhere
Phil
PostPosted: Mon May 02, 2011 4:57 pm    Post subject: Reply with quote
If it goes in parallel to every throttle body on the engine side, it think it goes to the purge of the chabon canister (for the fuel tank vapor) that is located on the right side of the radiator. There is a solenoid over the canister and that pipe should be connected there.
camaross621
PostPosted: Tue May 03, 2011 10:50 am    Post subject: Reply with quote
passanger side of the rad? hmm. this connector is coming off on the drivers side. its def pulling vacuum too. it does go parallel to all the throttle bodies and connects to each one
Phil
PostPosted: Tue May 03, 2011 12:08 pm    Post subject: Reply with quote
Yes it's on the passanger side of the rad. Here are pictures I took a fiew years ago before I have dismantle and clean everything
Vaccum pipes:
Solenoid valve:
camaross621
PostPosted: Wed May 04, 2011 9:21 am    Post subject: Reply with quote
very interesting. I even found those two wires on the valve. I wonder why it was removed in the first place because I def didnt take it off when i dropped out the motor.
camaross621
PostPosted: Wed May 04, 2011 9:28 am    Post subject: Reply with quote
phil the first pic of the vacuum line is on the top of the throttle bodies. mine are connected but they go into a vacuum block.
the one where I can not find is on the underside of the throttle bodies though. in the first pic
camaross621
PostPosted: Wed May 04, 2011 9:30 am    Post subject: Reply with quote
Phil
PostPosted: Wed May 04, 2011 12:56 pm    Post subject: Reply with quote
Camaross621, could this be what you are looking for? That pipe goes to the manifold absolute pressure sensor and is in the area of the one you are looking at.
camaross621
PostPosted: Tue May 10, 2011 1:48 pm    Post subject: Reply with quote
ok phil. that line does connect the black connector in those pics. where does it go from there? its just hard to see and there are no vacuum diagrams anywhere that I can find. my buddy is helping me try to figure this out. hes thinking that this is why I am getting code 62 and the trex stumbles over 4500rpms
Post new topic   Reply to topic    T-Rex of America Forum Index -> General Discussion All times are GMT - 4 Hours
