camaross621 Contributing Member
Joined: 12 Oct 2009 Posts: 128 Location: philly burbs
Posted: Sat Apr 02, 2011 9:34 am Post subject: got the trans. its coming together slowly |
thursday I recieved my built trans gears from R@D motorsports. the gears are undercut and cyrotreated and Mark did a few mods to them. Friday my brother and myself pulled the trex motor apart and swapped out the bad gears for the built one.
The trex only had 1st and and Neutral. when it would shift into 2nd, the rear tire just locked up. We ended up pulling the small gear set out and found a broken C clip which was allowing the 2nd gear to slide into 2+4th hense locking up the trans.
just some pics of the progress. just need to order a clutch, full the motor with fluids and hopefully get it together sunday.
its finally coming together _________________ 2007 T-rex.. in a million peices |
Posted: Mon Apr 04, 2011 12:17 am Post subject: |
now that is pretty  _________________ "OUT TO LUNCH" and not coming back. |
