Air Filter
Post new topic   Reply to topic    T-Rex of America Forum Index -> Technical
ViperSSSS
PostPosted: Sun Feb 21, 2010 8:06 pm    Post subject: Air Filter Reply with quote
Does K&N make an air filter that replaces the stock filter? If so, please let me know the part number.
Also, is there a trick to putting the ram air hoses back on to the airbox? They were pretty hard to pull off, so I would imaging I will have trouble putting them back on. Should I attach them before or after I put the engine cover back on?
2007 Blue T-Rex 1400R
Muzzy M10 Full Exhaust - Flies Removed - PCV with Autotune
WAYNE 07
Lost & Confused
PostPosted: Sun Feb 21, 2010 9:50 pm    Post subject: Reply with quote
No K&N does not make a filter for the 1400 but I have spoke with the factory and we are trying to see about finding a smaller K&N filter and making an adaptor to install them in the existing box.
Put the cover on first and then just keep spinning the hoses back and forth while pushing in. They are not that bad.
X-treme-toyz.net
LIFE`S TOO SHORT
View user's profile Send private message Send e-mail Visit poster's website
ViperSSSS
PostPosted: Sun Feb 21, 2010 11:25 pm    Post subject: Reply with quote
Wow, that is hard to believe! K&N is fairly close to me so I will give them a call and see if they are interested in making a filter for the T-Rex. I think they will do it, but they always want to see the vehicle. When I got my H2, I called them and they had me come down there to measure it. They sent me a free filter and also a cold air induction kit which was really sh*tty and wound up going in the trash.
loki
PostPosted: Mon Feb 22, 2010 11:30 am    Post subject: Reply with quote
Actually the k@n that fits is for a 1990 pontiac grad prix turbo!cross referencing the napa # is a bitch!I believe its hp-332038!will double check today:)
ViperSSSS
PostPosted: Mon Feb 22, 2010 11:52 pm    Post subject: Reply with quote
That is the correct part number for the 1990 Pontiac Grand Prix, but it definitely won't fit the 1400R T-Rex.
I did a search by size and one of these should work. I was thinking about ordering the 33-2094. The others look like don't have flat sides. It's either do that or use Wayne's idea of getting a smaller one and making an adapter plate.
http://www.knfilters.com/search/product.aspx?Prod=33-2094
http://www.knfilters.com/search/product.aspx?Prod=33-2881
http://www.knfilters.com/search/product.aspx?Prod=33-2930
http://www.knfilters.com/search/product.aspx?Prod=33-2952
WAYNE 07
Lost & Confused
PostPosted: Tue Feb 23, 2010 12:01 am    Post subject: Reply with quote
Thanks for the info. I will contact them tommorrow and see if they can make one for the T-rex.
X-treme-toyz.net
LIFE`S TOO SHORT
ViperSSSS
PostPosted: Wed Feb 24, 2010 9:43 pm    Post subject: Reply with quote
Well I went down and picked up a NAPA GOLD 6138 until I have time to go out to K&N to see if one of those filters will work. I was surprised to find out that it DOES NOT FIT without modification. The lip on the edge is too thick. The filter that was in there was a Purolator A24346(?). It was also shaved down to fit. It looked like a hack job done with a razor knife. I don't think it was done well due to the sand in the airbox. It most likely can't be shaved down so the whole lip is even. I guess gaskets seal will solve the leaking around the edge but it might get sucked into the engine. I can't believe Campagna would make an airbox that you can't get a properly fitting filter for! This is completely ridiculous!
ViperSSSS
PostPosted: Tue Mar 02, 2010 12:22 am    Post subject: Reply with quote
Question So does Campagna sell an air filter for this thing? Question
chicknfeet
PostPosted: Thu Mar 04, 2010 3:19 am    Post subject: Reply with quote
yes... call you tomorrow
diveocean
PostPosted: Fri Mar 25, 2011 9:49 pm    Post subject: k&n Reply with quote
So has anyone heard about a k and n filter yet or made and adapter?
Rob
Doog
PostPosted: Tue Apr 26, 2011 8:30 pm    Post subject: filter Reply with quote
Did someone ever came up with a after market filter or not for the t-rex 2010 scratch
The Life is good...
GRex
PostPosted: Tue Apr 26, 2011 11:48 pm    Post subject: Reply with quote
The NAPA Gold 6138 fits perfectly in my 2010 RR - no shaving. It cross references to a 1989 Cavilier 2.0L engine.
2010 White/Silver 14RR
- Albert Einstein
Doog
PostPosted: Sat May 07, 2011 2:45 pm    Post subject: Reply with quote
I just install a k&n filtre today no 33-2881 took me five minute just cut the black plastic box were the filtre goes WOW what a difference more HP faster rpm it's crazy order one it's a must have for a 1400 3gears
The Life is good...
WAYNE 07
Lost & Confused
PostPosted: Sat May 07, 2011 7:21 pm    Post subject: Reply with quote
Awesome. Thanks Ron thumleft
X-treme-toyz.net
LIFE`S TOO SHORT
Post new topic   Reply to topic    T-Rex of America Forum Index -> Technical All times are GMT - 4 Hours
