Michaelg Contributing Member
Joined: 04 Jun 2009 Posts: 129 Location: Wheaton Illinois
Posted: Fri Jun 12, 2009 10:41 pm Post subject: Runs like Sh*t |
| I am having a problem with my ride. When I start up it sounds like I am running on two Cyl, Also backfires alot. After I get full temp on the engine it runs perfect. I came up with either fouled plugs that clean out after I get temp or somthing not right on the enricher (choke) circut, tho I am not sure how that works. I don't think its the power commander as it would not straighten out. Bad Gas maybe? The thing I cannot fiqure out is why when it is warmed up the problem is gone. Any suggestions to check? Thanks |
haya Contributing Member
Joined: 04 Jun 2009 Posts: 290 Location: Québec ,canada
Posted: Sat Jun 13, 2009 11:53 am Post subject: |
| look if all the sensor are connected, 2nd, disconnect your power commander for test, , if problem again maybe a sensor is defect ???, do you have a 1400 ??? |
Posted: Sat Jun 13, 2009 11:55 am Post subject: |
| ok y oure in the 1200 section, so it's a 1200, maybe the gaz pump is defect or look at the carburator the small jet is maybe block , and a lot of 1200 have cam's problem ??? |
J-rex Contributing Member
Posted: Sat Jun 13, 2009 12:30 pm Post subject: |
| It's a 1400 I've seen the bike. I also don't believe you can use a power comander on a 1200 |
Posted: Sat Jun 13, 2009 3:48 pm Post subject: |
| Michaelg, you're getting all the gooffy problems! Have you been hanging around K3? |
K3 Contributing Member
Posted: Sat Jun 13, 2009 6:58 pm Post subject: |
| I think all DGY units come with strange bugs free of charge. |
Posted: Sat Jun 13, 2009 7:06 pm Post subject: |
DGY = DONE GOT YA!  |
Posted: Sat Jun 13, 2009 7:23 pm Post subject: |
| twn454 wrote: | DGY = DONE GOT YA!  |
LMFAO- but that is 100% true |
Posted: Sat Jun 13, 2009 8:24 pm Post subject: |
| Ouch!! |
Posted: Sun Jun 14, 2009 12:56 pm Post subject: |
| I should have put under right heading 1400 |
